CoolMaN - Citroen XM 3.0 V6 24V (1999)
Hello from Sofia / Bulgaria.
This is my XM II 3.0l V6 24V (ES9J4, gearbox ZF 4HP20/BVA4) 194hp
http://s3.postimage.org/qf47zxms/DSC_0041_copy.jpg http://s1.postimage.org/dj7xu9fo/DSC_0044_copy.jpg http://s2.postimage.org/10on70spw/DSC_0047_copy.jpg
http://s2.postimage.org/10os5mu78/DSC_0062_copy.jpg http://s1.postimage.org/e4t8fdj8/DSC_0016_copy.jpg http://s4.postimage.org/c10k17fo/DSC_0008_copy.jpg
http://s1.postimage.org/eyy4z1hg/DSC_0037_copy.jpg http://s4.postimage.org/cqf484is/DSC_0057_copy.jpg
Pieter Oonincx is Doctor Vems, Dave (D of DP) has helped forming some parts of the VEMS and they are the official VEMS suppliers in the NL and are well known over whole Europe for their stunning projects and quality parts
DP build all their projects with VEMS so with all respect for van der Laan, I certainly will vote for DP.
And about the do's and don't concerning citroen's: Dave and Pieter both have a PSA hart ;)
I don't think van der Laan will supply the parts needed for the 320 hp as DP makes the (turbo)parts themselfs.
The maximum torque is the limiting factor, not the power.
It is the same problem with the 3.0HDI, the torque is almost the same as the 2.7HDI but the power is increased. Both engines have the same compact Aisin automatic gearbox, which allows a maximum torque of 450Nm with reserve included.
2.7HDI 440Nm @1900rpm, 208hp @4000rpm
3.0HDI 450Nm @1600rpm, 241hp @3800rpm
Jaguar uses the same 3.0HDI with 500Nm @2000rpm, 241hp @4000rpm, because of the transversale placed engine. This allows to use a bigger gearbox and is developed with a higher maximum torque with reserve included.
The 2.7HDI has the same specifications as Citroën, because this engine was optimal engineered for its dimensions and was not allowed to tune it more. This why the 3.0HDI is launched which allows optimization to meet emission legislation in the future without developing a new engine again.
Hi there Coolman,
You can read the planning on the site: http://www.xmclub.nl/index.php?option=com_seminar&Itemid=55. It is in Dutch of course, but at least you have the dates. :D
Exactly! Come to Citromobile in "Vijfhuizen" near Amsterdam. It's really big and offers you lots and lots of Citroëns and all kind of things related to them! :D Mainly old stuff (Traction 2CV DS & CX) but it's worth the journey!
Heee Nice!!, and how will you be recognizable?
A red rose in a buttonhole off youre jacket? ore a string off icecubes around youre neck? :mrgreen:
