Citroen XM NOS parts
Hello everybody on this forum, my name is Milos and I'm from Serbia. Sorry to fall in like Merry Poppins, without any introduction topic, it's a bit hard since I use Google translate to read the forum. I personally own a BX, and XM remain my dream that will never come true.
The reason why I registered is that I managed to get my hands on pretty large pile of NOS parts, some of them for XM. Parts are mostly genuine from authorized workshop in Belgrade. Since I know how hard it is to find parts for these cars nowdays, I decided to offer them directly to owners instead offering them to some dealers. I translated parts list to English and added part numbers, and list can be found below. If admins or members disagree with this topic, feel free to erase it. :)
Here is the list:
1. Bumper bracket new - 95640667 (new number 7414.C6) - 1
2. Front left suspension sphere bracket without Hydractive - 5271.79 (just have to check the number again) - 1
3. Clutch plate 2.0 petrol without a box - 1
4. Clutch set Valeo TD without a box, some moisture damage  - 6541.K1
5. Air condition condenser without a box (new, but some dents on aluminium plates due to out of box storage) - 96134218 - 1
6. GRAF front brake discs 2.0, 2.1, 3.0 275 mm - 96054779 - 1
7. GRAF front brake discs 2.0, 2.1, 3.0 283 mm - 96099616 - 1
8. Handbrake cable - 96012379 - 2
9. Accelerator cable - 32903 - 2
13. Window trim OEM - 96020614 - 1
14. Complete left driveshaft with ABS, some moisture damage, without a box - 3272.90 - 1
15. Complete right driveshaft with ABS, some moisture damage, without a box - 3273.H8 (or HB instead H8, couldn't read clearly) - 1
16. Front right indicator without fog lamp Valeo, without a box, one damaged - 082757 - 2
19. Left exterior mirror with tinted glass and mirror heater OEM - no number on the box - 1
20. Body displacement sensor OEM - 96122910 - 1
21. Front grille part S1 damaged corner - 9600261577 - 1
23. Windscreen wiper switch OEM - 95637980XX - 1
24. Front hose OEM - 6457.Y1 - 1
26. Water hose 2.0 - 96086789 - 1
27. Water hose 2.0 - 1343.C6 - 1
28. Plastic part - 96077405 - 1
29. Water hose OEM - 96057424 - 1
30. Water hose 2.0 - 96086789 - 1
31. Fuel filler cap OEM - 9608890900 - 1
32. Air intake pipe to relay box - 96039554 - 1
33. Hydraulic reservoir compensator OEM - 96014072 - 1
35. GRAF water pump 2.1 diesel - PA542/1201.55/96047088 - 1
36. Brake caliper metal part Bendix//caliper joke front brakes - 95653170 - 1
37. Idle compensator OEM - 0345.56 - 1
38. Vernet temperature switch - 1627 - 7
39. Cylinder block core plug OEM - 0163.28 - 1
40. Boot light switch OEM - 95656499 - 1
41. Rheostat screw OEM - 1531.09 - 1
42. Air dosage housing bracket OEM 3.0 - 0363.26 - 1
43. SNT tensioner - 374356 - 2
44. Thermostat seal OEM - 1340.14 - 1
45. Stop switch FAE - 4057 - 1
46. Temperature switch diesel OEM - 95638684 - 1
47. Sachs release bearing diesel - 3151874001 - 1
48. Sensor/modulation motor (?) OEM - 6445.T3 - 1
50. Water hose without A/C OEM - 96043314 - 1
51. Tank filler cap - XS819 - 1
52. Timing belt tensioner diesel OEM - 0830.14 - 1
53. Timing belt tensioner diesel OEM - 0818.19 - 1
54. Engine bearing Vanderwell -0,30 mm - VDR92569A - 1
55. Osvat exhaust valve set 2.0 - 0989 BMC - 3
56. Hydraulic pump pulley diesel OEM - 96117523 - 1
57. Front left suspension sphere bracket with Hydractive used - 96149390 - 1
58. Air filter OEM - 9401444108 - 1
59. Hydraulic pump belt Rofan - 1A1025 - 2
60. Lower gasket set 2.0 Payen - 013537 - 1
61. Gasket set diesel without head gasket Ajusa - CT-7100-H - 1
62. Head gasket 2.1 diesel Glaser - 12354 70F - 1
63. Intake manifold seal 2.5 TD OEM - 0348.F9 - 1
64. Diesel gasket set OEM - 0197.H1 - 1
65. Gasket set 2.0 OEM - 0197.C8 - 1
66. Lighting switch, without a box, all covered with ducktape (can't stop wondering why doing such shit) - 6253.55 - 1
67. Cooling fan temperature switch OEM - 95638684 - 1
68. Temperature sensor OEM - 96018426 - 1
69. Water temperature casing OEM - 0242.73 - 2
70. Cooling fan temperature switch 2.0, 2.1 OEM - 96064561 - 1
71. Thermostat 2.0 without a box - 4638.89 - 2
72. Fuel pressure regulator 3.0 OEM - 1563.A5 - 1
73. Water temperature sensor OEM - 1338.09 - 1
74. Hydraulic tube fixing bracket OEM - 5280.J4 - 1
76. FRAD fuel filter diesel - 20.059K-43-59-02 - 4
77. Thermostat seal diesel OEM - 1339.66 - 4
78. Interior door lock button OEM - 96002473ZL - 3
79. Door hinge shaft OEM - 96085422 - 6
80. Gearbox lever OEM - 96068122 - 1
81. Temperature switch Vernet - 1627 - 4
82. Injector 3.0 OEM - 1984.82 - 4
83. Temperature switch FAE 3.0 - 37940 - 2
84. Hydraulic tube fixing bracket OEM - 5280.J3 - 1
85. Cooling fan temperature switch Vernet - 1769 - 2
87. Door window guide OEM - 95291417 - 6
88. Works connection injection+ZPJ+Diravi OEM - 96142040 - 1
89. Water temperature sensor OEM - 96092918 - 4
90. Upper radiator holder OEM - 96009729 - 2
91. FRAD fuel filter diesel -  43.59.02/30 - 2
92. Stationary window joint OEM - 96025938 - 1
93. Temperature sensor/heater core OEM - 95651014 - 2
94. Rear wiper motor+mechanism Bosch OEM - 95652999 - 1
95. Speed sensor OEM - 96008163 - 1
96. Steering rack shaft screw OEM - 4043.30 - 1
97. Water temperature sensor without A/C OEM - 96008159 - 3
98. A/C switch OEM - 96023272ZL - 1
99. Bracket for some sensor for A/C OEM - 6445.59 - 1
100. Clutch release bearing without a box - 96090882 - 2
101. Brake caliper metal part/caliper joke front brakes OEM - 4404.20 - 1
102. Caliper joke front brakes+sliders Bendix OEM - 95653169 - 1
103. Exhaust manifold 3.0 damaged by moisture - 0341.72 - 1
104. Intake valve Osvat 2.0 set - 780988 - 3
105. Engine bearing 2.0 repar OEM - 0606.J5 - 2
106. Heater control knob OEM - 95655230ZL - 1
108. Water hose - 96403800 - 1
109. Brake set column screw set OEM - 4448.68 - 1
110. Anti roll bar stabilizer link Sasic - 0875415 - 1
111. Stabilizer OEM - 5087.49 - 3
112. Front triangle arm wishbone bush OEM - 3523.44 - 2
113. Kolbenschmidt piston set 2.1 TD with piston rings, moisture damage - 90686610 - 1
114. Driveshaft bellow Sasic 3.0 100x30 opened bag - 2933983 - 2
115. Driveshaft bellow gearbox side 75x33 Sasic opened bag - 2873813 - 1
116. Driveshaft bellow Meillor - 329726H - 1
117. Bendix brake pads set - 571369B - 1
118. Front brake pads set LPR - IP05P328 - 1
119. Front right window lifter with sensor OEM - 9222.98 - 1
120. Front right window lifter without a sensor OEM - 9222.E2 - 1
121. Ignition cables GREGOIRE BARILLEAU without a box - 636599 - 1
122. Computer housing without a box OEM - 96089112 - 1
123. Crankcase for A/C models - 96014066 - 1
124. Front right suspension strut return tube 2.0 OEM - 96076633 - 1
126. Head gasket Payen 2.1 TD 1,64 mm - 047053 - 2
127. Head gasket Payen 2.1 TD 1,54 mm - 047052 - 1
128. Head gasket XUD11A Ajusa 1,7 mm - CT7105ADKS - 1
129. Head gasket Glaser 2.0 - 07967-80 - 1
130. Gasket set 2.0 Glaser with head gasket - S31115-80F - 1
131. Steering rack for models with Hydractive new, without a box, one tie rod end missing - 4000.T3
132. Headlight glass - have to check which side, I know I saw 2, could be for S2
133. Throttle valve contact switch 2.0 OEM - 1628.K9 - 1
134. Throttle position potentiometer 2.0 OEM - 1628.R0 - 1
UPDATE:
136. Intake valve 3.0 V6 OEM - 7910248148 - 6
137. Exhaust valve 3.0 V6 OEM - 0949.61 - 6
UPDATE 2:
139. Valve for early Hydractive models, without a box, looks like part number is 95637614, check the pictures here - link, link and link.
There are also a lot of parts for CX, AX, ZX, Xantia, Peugeot 605, 405 etc, so ask if you are interested in these parts - I could make lists of these too!
I'm here for any question you may have. :)
That's an interesting list of parts Milos. Good to know that they are still available somewhere. Even though it is in Serbia ;-)
Hi Veen. :) Well, Citroen is present in Serbia well before WW2, and after 60's it was considered a domestic car manufacturer since it had cooperation with factory Cimos from Koper. AX, GS, BX, XM, CX, Visa were widely spread, and many big state-owned corporations had XM's in late 80's/early 90's. That's why there is so many NOS parts in various old stocks all around Serbia.
